Arrik
My problem:
Steve's resolution:
Try getting that response from most any manufacturer.
Hi Steve,
My name is Mike Hechanova, Arrik on DVXuser. I am currently shooting a feature in CT and my z-american arm, which I've owned for a few months now (with no problems) seems to have a threading issue. I've been using a Nebtek NEB70HD monitor with the Panasonic Lithium ion battery upgrade. This puts the payload at about a little over 3lbs. The z-american has been great, but the last two or three shoots I notice the Nebtek monitor slips (even with a bend in the z-american position). To remedy this I would simply tighten the arm til slipping wasnt an issue. I would also lean the nebtek against a part of the camera to help take the weight off the z-american. But now, the z-american arm seems to have stripped because when I turn the knob it is not smooth. The arm also doesnt loosen when the knob is loosened. I have to fiddle with it. I can still get it to be somewhat rigid if I tighten hard enough but I know that shouldnt be normal.
I know the z-american should have no problems with a 3lb payload. Would I be covered in the warranty for a replacement or do you consider my actions negligent? To clarify, I currently have the old silver z-american arm.
Either way, you guys have been great. Thanks for the help.
-Mike Hechanova
Steve's resolution:
Mike,
Doesn't even matter to me if it is negligent. My warranty covers negligence. I want your Zacuto experience to be amazing.
Send me the arm with a this email in the package and I'll send you a new Zamerican arm. It should be able to hold much much more then 3 pounds with no slipping.
