Z1U capture settings for HDV in FCP
blando3
I have a shoot in a few days using the Sony Z1U and will be editing on my FCP system. For HDV, what capture settings do I use? In the drop-down menu for Capture Settings, there is a long list of formats, but I don't see HDV. Thanks...
Andrew
Use the Z1 for playback. At the end of the shoot hook up the Z1 via Firewire to the FCP and select HDV out to HDV in "easy set up" in FCP. Capture everything as HDV and edit in HDV and then output to SD DVD via DVD SP or if you need to you can output HD but you need to rent a deck. But that's later, first you want to preserve the HDV because you'll be able to uprez to full HD after you edit.
