O Ogrus Well-known member Jul 17, 2012 #1 I am using Pro CS6 I shoot PAL Why does the YC Waveform monitor show V instead of IRE values? Can I change this? Thanks!
Shooter Veteran Jul 17, 2012 #2 I dont think yu can change that..but effectively and practicaly the same thing.
O Ogrus Well-known member Jul 19, 2012 #3 I've been looking into this matter It because i shoot pal It's not the same measurement. I'm trying to figure out the equivalent
Ann Bens Well-known member Jul 19, 2012 #4 If you load pal footage you get volts, if you load ntsc footage you get IRE. But that is for analog, just ignore it. Make sure you stay between 0,3 and 1.0 volts
