Hi all;
I have a number of Tascam DR-03 recorders that I have to take to record concurrent sessions at a large convention center. The sessions are all voice--just speakers talking about various subjects.
The only rub is the patch bay at the center has XLR male outputs. I am worried about going from this XLR outputs to my Tascams which have a mini 3.5mm (1/8") input jack that accepts mic & line signals. Supposedly it switches automatically between the two depending on the signal. The Tascams have manual level control.
Questions I have: Will I get a ground loop if I connect these decks? Will I throw a ground loop into the rooms being recorded?
Should I use XLR female-RCA cables and then an RCA to mini adapter on the end?
And should these adapters be mono or stereo? The recordings dont need to be stereo, or both channels.
Also, should I bring some sort of Di box or hum eliminators?
I'm kind of in a corner here...
Thanks for any advice!
