XLH1 > FCP2 > Import setting HQ ?
Andii
Hello all.
I have been shooting with the Canon XL H1 for some time but wanted to know a little more
regards capturing the footage. I always shoot 25f (pal) and in HDV.
When it comes to actually bringing in the footage, what are the best settings to keep
the best possible quality? is it Prores? my footage still seems a little noisy (just a little).
Any suggestions? I am not talking gain ect, I just want advice on the capture side.
Also and this may seem like a stupid question, I was talking to somebody at a large production company who said that why didn't I capture using uncompressed 8 bit. My query was, isn't HDV compressed on the tape? does using this codec release the compression?
Any help or advice appreciated.[MOVIEHD][/MOVIEHD]
No, it doesn't "release" the compression.
Without going to much into the details, it simply gives you a higher quality codec to work in which can be advantageous if you are going to be adding effects, color correction, animation, etc. or simply as an intermediate codec so you don't have to use the HDV codec which is not designed for editing (it's highly compressed and demanding on your system). The disadvantage is that files are much larger and you'll need a system that can handle the load.
Having said that, ProRes is a very good codec and is specifically designed to be as close to uncompressed visually without taking as much space. There are also a couple of other intermediate codecs, but I'm not familiar with them.
Try capturing in a variety of codecs and comparing them visually and in terms of file sizes, wether or not your system can handle the load, etc.
Hope this helps.
