you can find much low cost good chinese brand ( check chiniz)
it already has 75/150 hz switch to reduce handling /wind noise
the low cut on octava don't worth to much as only reduce 3 db
about other mics you have at least 4-5 that will do it as schoeps but for much less .
about shotguns - there are some which actually act very good in reverb spaces ( in non reverb there is no any problem not to work with one)
cs-3 and schoeps cmit could work fine in 80-90 % of the situations
by the way better get 2 mics as shi* happens and sometimes you need to make 2 person interview
I'm new to the forum, so I hate to out myself as a net noob, but I'm not quite sure where to find "the stickies"...
