XH A1 and SGPro?
cordvision
Next month I will shoot a project with an SGPro and a XH A1. Is there anything I have to be aware of? How far do I have to zoom in approximately to achieve a 35mm academy FOV with the SGPro? The XH A1's 24F mode isn't true progressive right? How does it actually work and what kind of pull down is used to save the images to the tape (is it 24p or 24pa, or something else)?
Thanx,
Michael
Theres a guy on the SGpro rofum called Dave who uses the same setup and some of his stuff is pretty spectacular so it defiantly works, he will be able to tell you more though.
In regards to 24f vs 24pa...I use this setup and have no pulldown issues using Vegas Pro 8. As far as academy..I believe the SGpro is already setup for that when you focus onto the GG. You should go to the shoot35.com forum and ask Wayne any specifics that you may need.
