redcap said:I'd just go for an internal solution.
Oh and those promax solutions are horridly overpriced. Geeze. I could string together an excellent SATA raid for half those prices, and it wouldn't require that external box either.
An extra matching drive to the stock internal on a G5 (which already has SATA) would probably be sufficent. I usually get around 130 megs/second and upward read and writes.
Theres this interesting solution I was looking at that allows you to mount up to three drives in the extra space in the G5's case along with extra SATA cards, it claims that the built in fans are ample for cooling. Anyway you could easily set up a 4 drive raid and get even fast speeds of probably 200 meg/second (or so they claim.) Which wouldn't suprise me. If you wanted even more speed you could get the 10k rpm drives, but they're limited to about 72 gig's for $210.
You'd want to go for an xraid if you were sharing the same footage across several editing stations, and you'd ideally have those stations hooked up through a gigabit ethernet switch using cat 6e cable. Ideally, or better yet a fiber channel interface straight into the xraid, but boy can that get expensive.
