how would you like to edit uncompressed HD or SD at 30, 25, or 24 fps at any standard res up to 1080p at 30 fps, with full professional controls like genlock, and ucompressed SDI comprehensive primary and secondary color correction and matching and blah blah all the bells _+ whistles + other pro stuff you want (including support for HDV, and HD DVD and HD mpg i-frame compression and so on) and in realtime for both HD and SD,
well..
check out the latest product from matrox.. :
http://www.matrox.com/video/products/pdf/axio_guide.pdf
or
http://www.matrox.com/video/products/axio/home.cfm
i have to say .. bravo.. this is a big step above the current products. and im glad to see it happen
p.s. what this also likely means, since it is planned to suuport HDV and other formats, is that adobe ppro will likely be offereing HDV and other HD format support as well aside from what HD support it already has... which is good news.. speculative still as of this moment, and any official release, but an educated guess that i would bet on none the less, since matrox is so closely tied to the Adoebe software.
well..
or
