World's First Microprocessor Managed 35mm Lens Adapter!
Dennis Wood
DVXuser Sponsor
It's been a very long coming, but we're very pleased to announce the Brevis35 MP.1 (Patent Pending) has arrived, and is shipping today. The Brevis35 system remains optically unchanged, however what's under the hood is very much different. Here's a summary of changes:
- The designation MP.1 simply means "Microprocessor, Firmware version 1". The onboard firmware is upgradeable!
- Oscillation and power management are now very precisely controlled by the onboard microprocessor.
- Critical oscillation properties can now be adjusted and tuned externally, with the adapter system fully mounted on your camera.
- The power LED now flashes a warning when you have 1 hour of runtime left.
- If you forget to turn the unit off (and you will, because it's whisper quiet), an auto shutoff feature is now standard at low charge.
- Runtime has increased to 32 hours on the standard 15 to 25 minute charge using our included smart charger.
- Internal power cells and motor can now be replaced in the field if ever required using our modular connection system. In other words, plug and play.
- The power switch is new, lower profile and sealed in a slick rubber boot.
- Power pod use remains unchanged should you want to increase runtime to 70hrs using two AA batteries externally.
- Our exclusive micro-collimation system remains unchanged across the entire lens mount range.
- The interchangeable CINEFUSE imaging element system remains unchanged so one adapter can be used with full frame widths on everything from the HV20, to the HPX500.
- Weight of the unit is identical...still the lightest system on the planet for all cameras.
In keeping with our policy of not stranding past customers, the updates are 100% applicable to existing REV2 units! The upgrade package will be posted later today in our catalog. Cost will be $180 and will include the new electronics package, switch, LED, power cells, rear shield and charge jack. Return shipping will be calculated based on your shipping location during the ordering process.
There's more:
1 The new rails system announcement come's later today.
2. We were approached some time ago by several vendors regarding sale/distribution of our products. Vistek in Canada, and B&H photo in the US will be carrying the new MP.1 units.
3. We'll be at NAB as guests of B&H photo in their "Studio" section. We'll have two of the MP.1 units there as well as the new rails system. Stop by and say hello!
