DELTA_Rotary
Are there any workshops or seminars out there that help with getting the most out of the 35mm adapters?
Timur's the mod over 35mm adapters, you should direct your request to him. He'd be making the stickies and organizing the info that goes into them.So far my request has fallen flat - perhaps because I am a mad dog proponent of phenomena that all wiser heads know are optically impossible.
If someone ... just wants "shallower DOF than they would otherwise get, the Brevis does that just fine
People who want to buy cheap lenses and get ultimate light efficiency and are not put off by the side effects will be well served
if someone wanted linear response (1 stop = 1 stop)
It "games the system" by doing things that we didn't expect, that shouldn't work....he's invented the "pixel shift" of adapters...
There are side effects and there are tradeoffs. We've now been able to identify what those are
You must be kidding. Attack? I'm pointing out that it behaves differently. How is that an attack?Barry,
I have to say that your post saddens me a great deal. Why you see the need to personally attack a perfectly good piece of equipment from a reputable and hard working manufacturer who brings his time and expertise to these pages is utterly beyond me. Have you ever actually tested a Brevis?
Okay, let's attempt to clarify this: I'm saying that with a CF1L the Brefis is going to have deeper DOF than the others. More in focus. That's what I said the last time, that's what I'm saying this time. Is that what you're saying?The Brevis CF1L has "MORE" DOF than a Letus or an SGPro not less.
Exactly. That's what I'm saying, that's what I've been consistently saying.its a fact and any number of people here could tell you the Redrock for example has less apparent DOF. In general - more diffusive GG - less apparent DOF.
Where did you get the term "real 35mm adapter?" Stay on point please. I'm saying "does it emulate the DOF of 35mm movie film?" That is an identifiable, tangible, non-subjective criteria. If it doesn't, and it doesn't even attempt to, then that's a point of data that one should know about. That is not, however, by any stretch of the imagination, an "attack."So - which one is the "Real 35mm adapter"?
Er, well, I disagree. Five minutes with a tape measure and a DOF chart would tell you whether it complies or not. And a cinematographer like David Mullen or Levie Isaacks could probably say within seconds whether it's what they expect or not. Guys like that ask for a lens by name because they know its field of view and DOF characteristics, and they expect a certain level of performance.I doubt whether you or anyone else here could say with reliability which of these is closest to the DOF of true 35mm
It makes no difference whatsoever. If the adapter is emulating film's DOF, it will do so whether you zoom in to Academy or Super35 frame size.- and by the way is that Academy or super 35?
Your assertion would appear to be backwards. Since film is an opaque surface, the more opaque, more diffused ground glass should trap the most light and yield the most consistent DOF. I haven't really understood your argument heretofore; I think you're trying to say that you think that the less-transparent ground glasses are making the image unnecessarily fuzzier or something?Again, if I had to bet I would guess its the Brevis because it doesn't add additional diffusion due to the GG. It should be closer to the expected optical DOF of film.
Not yet, and that's exactly what I'd like to see. I am privileged to a lot of extensive in-depth testing results that have identified exactly what the Brevis is doing and how it affects the image, related to light transmission and linearity. I am also aware of tests such as those done by yourself that indicate that there is no DOF difference on a Brevis when opening up from 2.0 to 1.4, etc. Based on both of those, it seems a very simple extrapolation to say that the DOF of the Brevis/CF1 is going to behave similarly to its light linearity. In fact, I'd go so far as to bet $100 on it.I think it would be great for someone to compare DOF on these adapters with that in a chart. I haven't seen it. Have you?
I don't even konw what you're talking about here. Who said anything about what frame sizes it's letting you have? All I'm saying is that it doesn't deliver the SAME DOF, and delivers DEEPER DOF, than film would. And that is an important factor, at least for some of us. It is not the only factor, and for many people it's irrelevant. That's fine. But don't you think people would be better off knowing what the tradeoffs are? That is not an "attack". Sheesh, if I point out that the Red has a rolling shutter, is that an "attack"? Or is it information that you'd be glad to know about? Some people don't care at all about a rolling shutter, they know what it does and they know it's not going to affect them. Some know that it prevents the product from being suitable for their purposes. Both are served better by knowing what the situation is.2. The Brevis is just as capable of giving you Academy as any other adapter and like most of the others - (including Redrock & Letus if it was centered) it gives you full frame as well. They sell PL adapters. So that's a complete non issue. I don't know where you got this idea.
Straw man argument. You can use all the frame you want, Lenny. I never said you couldn't. Go right ahead, use 6x6 if you want. But please don't try to tell people who have valid reasons for wanting to use a cine frame that they're wrong, and that "full SLR" is "better." They are choices, they are valid choices depending on what you're trying to accomplish. Trying to gloss over the differences does a disservice to the end user.But I take issue with the implication from you that there is something wrong with people who wish to use the full SLR framing.
Frankly, no we cannot, unless you want to give up the term "35mm adapter" and instead refer to it as a "DOF adapter". A 35mm adapter inherently implies that it emulates 35mm, which is what the mini35 was specifically designed as. And if you want to emulate 35mm, you presumably want to emulate the field of view and depth of field characteristics of 35mm. If you are not interested in doing that, and you only care that you're getting shallower DOF than you otherwise would, go right ahead. But recognize that those are not the same thing, please.So can we please discuss it as an aesthetic choice instead of some god-given principle upon which 35mm adapters were created.
Do you really think that's what I just said? Let's try this again: CineVate markets the unit as being especially appropriate for those who have slower lenses. CineVate markets it as saying that you don't have to go out and buy the very fastest lenses on the market, you can save money and use slower lenses because you get equivalent light performance. That is their marketing. That directly translates to what I said, although I assume you're objecting to the term "cheap".What the...? I own only the fastest Nikon Primes and the excellent Nikon 2.8 80-200. Plenty of other people here using Brevis have invested in good glass. Are you really implying that this tool is only for people who buy cheap glass?
Of course I have. It's fantastic.Have you seen Marco's feature work and those of other people who've used a Brevis here?
And that's exactly what I said. And I thought it was perfectly reasonable too.The speed advantage is there for anyone who wants to use a zoom lens, or who would rather shoot with their 35mm lenses at 2 or 2.8. Or save on f1.4 lenses. That's perfectly reasonable Barry.
And that extremeness is all I was referencing. The other adapters, as I've recall, are fairly linear from 2.8 on down. The CF1L is not.They are not as extreme as the Brevis but elicit some of the same behavior, because it is in the nature of the optical behavior of adapters.
Are you reading what I'm writing? Or are you just "assuming" you already know what I'm going to say, and responding to that?Huh...? Dennis designed a screen for minimal loss of light - for those who wanted it. Period - that's all he did. Everything else that seems odd is due to the optics of adapter mechanics and it surprised all of us because we were used to the different optics of film.
I did.What is all this invective here for? Its a tool. You should be thanking him.
THAT'S ALL I'M TRYING TO DO! Sheesh mary louise parker in a handbasket, that's all I'm trying to do. People who ignore the obvious side effects are the ones obfuscating the issue!!!!Let's understand it and see what its real trade offs are.
Only in your misinterpretation of what I said. The Brevis CF1L exhibits deeper DOF, not shallower. That is what I said and that is what I meant. And that is the tradeoff; that plus the loss of linear light control at anything more open than, say, about f/8.What trade offs exactly have you identified? The DOF analogy was completely upside down
For you, maybe, but it's borderline outrageous that you could empirically declare that it's a nonissue for everyone else.The academy vs. 35mm framing issue was a non-starter altogether.
Fine -- AS LONG AS YOU KNOW ABOUT IT. That's all I'm trying to do.Few of them have 1:1 response, but I imagine if that seriously upsets one it could be a downside. Personally I think it would be very easy to work around.
There must have been some kind of tradeoff, yes. To deny that is simply irrational. You cannot get something for nothing, there is always a tradeoff. We suspected there must be a hotspot, but frankly there isn't. The tradeoff that exists, as confirmed by the testing that I have been shared but is not my place to reveal, is in the DOF performance and light loss nonlinearity. Now that it has been identified, people are empowered to make an informed decision.Last month all kinds of people here were announcing that there had to be some kind problem with the Brevis pictures- they must vignette, or they can't handle highlights, etc - but neither you nor anyone else has found anything of significance yet.
Interesting choice of invective there. Considering that I think I have probably one of the better understandings of what's going on, and would certainly be willing to put my understanding up against anyone short of an optical engineer. I did not always know how they performed and have been curious. My curiousity is now satisfied.6. What I read in your remarks is an appalling lack of curiosity as to how adapters actually behave.
Isn't that what we've been discussing and, in fact, basically settling here?What affects their DOF characteristics, What affects their linearity, what are the pros and cons of academy vs. SLR framing and DOF, how to use a DOF chart with any of them, why would the Brevis CF1L act as it does and what are the REAL TRADE OFFS between any of these.
That's your interpretation of what they are. And if you're okay with that, then great -- you're happy. But that is not necessarily what they "should" be.They are peculiar inventions that allow us to get very pretty low DOF images using all kinds of 35mm lenses on a video camera. That's it.
Please, let's. And the first step is to stop discarding perfectly valid methodology and reasons and criteria.Lets learn how they work in a responsible intelligent reasoned way.
Says who? I've used every adapter on the market except the Brevis. And I still stand by my claims for the Letus, but one part that you consistently leave out is that: I do not care for any upside down adapter. That is my criteria, and any upside down imagery is, in no uncertain terms, unacceptable to me. We all have our priorities, and that is mine. I'm simply not going to plink around with preposterous workarounds for upside-down-ness. So when the L35FE came out I bought one, and both Steven and I were amazed and delighted with it, even though it certainly had its share of tradeoffs. When the Extreme came out, it erased all the shortcomings of the FE. So I declare it, today, my favorite adapter, having used all of them (excepting only the Brevis). However, the landscape has changed now because there are flip modules that close the gap.When the Letus Extreme came out , you and others made a number of catagorical statements - it was the fastest, sharpest from corner to corner, the most well built by far, etc ... but you had not actually compared it to the others
The FACTS is all I'm interested in sticking to. I know that you've taken on adapter-ness as a personal mission, you're one of the most devoted in trying to get to the bottom of all this, and I and the community express our heartfelt thanks to you for doing so. But yes, let's stick to the facts. Observable, scientific, non-subjective evidence, and the understanding of any real-world implications that may come from the different techniques employed by each.I have a great affection for you Barry, have had fruitfull private discussions with you and have learned a great deal from you, but this post was really over the top and demanded a response. Let's stick to the facts.
Barry Green said:Frankly, no we cannot, unless you want to give up the term "35mm adapter" and instead refer to it as a "DOF adapter". A 35mm adapter inherently implies that it emulates 35mm, which is what the mini35 was specifically designed as. And if you want to emulate 35mm, you presumably want to emulate the field of view and depth of field characteristics of 35mm. If you are not interested in doing that, and you only care that you're getting shallower DOF than you otherwise would, go right ahead. But recognize that those are not the same thing, please.
If someone doesn't care about measurable results and predictable performance and instead just wants "shallower DOF than they would otherwise get," the Brevis does that just fine.
As for "optically impossible," the claims turned out indeed to be optically impossible for a unit that would have been attempting to capture the frame and emulate the DOF of 35mm.
It "games the system" by doing things that we didn't expect, that shouldn't work, and -- by strict interpretation of what an adapter "should" be doing, don't work.
People who want to buy cheap lenses and get ultimate light efficiency and are not put off by the side effects will be well served,
Lenilenapi said:I do more docs, spots and corporate than features and so do many many video shooters. My clients always want less DOF especially in interviews - so I have the advantage of SLR's lower DOF and I prefer my SG's shallower DOF. It is a godsend to us. On many shoots my client wants a wider shot than my lenses allow. Should I say - Sorry can't do that I'm emulating Acadamy DOF here? I am also wary of too shallow DOF in drama and sometimes need every bit of light I can get. Here the Brevis has an advantage and so might Academy's deeper DOF.
What I have always objected to, and will continue to object to, is a blanket portrayal of something as "better" or as an "advantage" without exploring what the potential side effects or tradeoffs are.
