grahamdunn
Hi there,
I am working with some footage shot on film at 24fps and telecined to 720p, 59.94 (smpte standard progressive).
There is of course some frame doubling etc. to fit the 24 into the 59.94 framerate and get it to play back in real time. When working with this footage, I am keeping it all 59.94, but that means the program must render 59.94 frames a second instead of 24, so it's kind of bogging things down.
Is there some sort of pulldown removal I should be doing (the normal interpret footage dialogue 3:2 removal makes the framerate 47.953), or should I just keep plugging away? If I try setting the comp to 29.97, the frames are slightly different here and there from when it's 59.94, though the duration is the same. Any help would be great.
Thank you!
Thank you!
