pjwoodside
Hi all,
I'm an award winning editor -- in fact, we'll be appearing in the Sony Creative Software newsletter in January, but the technical aspects sometimes hang me up.
We've been working with Vegas on SD projects, but we recently switched to HD -- P2 files (.mxf) and acquired Sony Vegas 12. I've done a rough cut for our next feature-length movie, and I'm giving some consideration to the best workflow at this point. Here are my issues:
--There are at least 123 scenes in this movie. It's about dreaming, so there's a lot of jumping.
--Many of the scenes are from the same location and will need the same types of adjustments with color correcting and sound editing
--I like to sound edit initially from files in the same batch of takes
What I've done initially is pulled ALL the files for a set of scenes into a vegas track and organized them and labeled them with markers so if I need one I can find it easily. This worked great for rough-cutting and will possibly work fine for sound editing and color grading.
However, when I get to the point where I want to pull pieces together, what's the best way for me to do this?
--pull the rough pieces all into one vegas file and work with numerous tracks in that file?
--divide the movie into sections and work with something similar to the above but in smaller chunks?
--OR, render the pieces into .mxf files and pull them onto a track together and then add score and sound effects (taking them back to their original files and re-rendering when necessary for changes)
--OR, do the same as above except in a different format?
I am worried that rendering already rendered pieces somehow loses quality, but it sure makes the workflow a lot easier toward the end.
If you have any insights or resources, please post links for me. Thanks in advance!
pj
pj
