workflow questions
dajavudesigns
so i have a scene all over my project and i color corrected the first clip, is there a quicker way to paste the color corrected effects instead of going and finding that scene in my project clip by clip and pasting the settings?
for example in a music video when i color correct like 5 different scenes that i use a bunch throughout the whole video, is there a way i can easily paste my color corrections from one of the scenes onto all similar scenes that i want the same effects applied to?
hope that makes sense
i tried grouping in premiere before i went to after effects
One way, would be to create a new comp with the same settings as your clips. Pre-comp each of your clips (minus the colour correction) and then move them into the new comp and position in the timeline sequently.
Add an adjustment layer, on top, and apply your colour correction to this adjustment layer... your done ;)
The easiest way to do it is to select all the effects you've used once you've tweaked your settings. Once you select the effects you want go the animation menu and select the make animation preset or whatever it's called. Then you can just add the animation preset to your other clips and it'll apply all your effects and settings you had selected when you made it.
