workflow for adobe dynamic link
vonkuttenberg
hello, what is the workflow for this editing using ADOBE DYNAMIC LINK? thats a great feature but by some reason it does not work as should.
i want:
1. edit in premiere.
2. import and add effecsts in after effects, adjust colors
3. import back back to premiere and export including sound?
when i save sequence in premiere, import to AE and than with effects import back AP i see all videofiles offline :-(
Hi Vonkuttenbert,
Looking at your workflow, the third step is not necessary with Dynamic Link (DL). From PPro, one simply chooses a single clip or more, right click and choose Replace With After Effects Compostion, then the comp appears in AE and is shared by both apps. There is NO NEED to import back to PPro as you are sharing the comp via DL. Any changes made in AE will automatically update in PPro. When you are ready to output, PPro will hand off the timeline to Adobe Encoder for the final render. Hope this helps!
so this workflow system works for coloring of the entire sequence and adding tricks? i tried it with one clip but i did not tried with whole sequence yet...
