Postmaster
Dark Side of the Camera
This one sounds very interesting, thou $999 is a bit steep.
But with all those new cameras with HDMI out that would be a nice to have option.
http://www.popsci.com/gear-amp-gadgets/article/2009-01/finally-–-wireless-hd-works
Frank
http://www.gefen.com/kvm/dproduct.jsp?prod_id=4318
Frank
The First Wireless HDMI Extender featuring Cable-Free High Definition Extension up to 30 Feet.
The Gefen Wireless HDMI Extender is the perfect solution for sending up to three High Definition AV sources to any one location without the hassle of wires. The Gefen Wireless HDMI Extender is able to accomplish this by employing Ultra-Wideband (UWB) technology to send the large amounts of data required by the HDMI standard. Up to a 30 foot line-of-sight distance (less if going through a wall to an adjacent room) is achievable with supported resolutions of up to 1080p@30.
This is a perfect solution in scenarios where traditional cabling cannot be applied. The plug-and-play installation makes it simpler than ever to extend HDMI to another room or to a ceiling projector in a matter of minutes, all without ever having to run cables and drill through walls and ceilings.
The Gefen Wireless HDMI also doubles as a High Definition video switcher. There are three High Definition video inputs (2 HDMI and 1 Component) that are selectable by the transmitting unit.
If the wireless receiver is located in an remote location, the IR repeater feature will relay remote control commands from your location back to the source. Once the IR blaster is properly placed, simply pointing your existing remote control at the receiver will send the remote commands back to your AV source device(s) for a truly seamless experience.
