naeem
Hi;
I use Sorenson 4.1 for wmv output. I've found the wmv files are smaller than Quicktime's MOV files - so that's the direction I'm heading. Anyone disagree with that? (If so - please tell me what tests you did to compare the two).
Now the problem with wmv, with Sorenson, is I can't watermark my logo on the image! If anyone is a pro at using WM Encoder, please tell me how:
- Can I put a water mark on the output video?
- Can I change the default wizard out settings? The minute I change the bit-rate - it tells me I have a "bad" source file ????
- Can I join 2 (or more) videos together?
thx!
thx!
