Well, now I'm really confused.Obviously it won't be available right away, as 1080/60p is only an AVC-Ultra mode.
??? But Barry, in the other thread that I linked back to, you yourself said "and I have now received confirmation -- AVCI-100 at 1080/60p is, indeed, 200 megabits per second, as verified by the head of the engineers at the Panasonic factory"No, because AVCI-100 is an existing standard, and 1080/60p is not part of that.
Well, I don't think it's an either/or choice........Now, you can either accept that the manufacturer believes they have a coherent story here, or you can continue to confuse yourself. Your choice.
so that mentions it now encompassing a long-GOP mode, a Proxy mode, Class 200 and Class 4:4:4 - but no mention there either that Intra100 is also part of AVC-Ultra when applied to 1080p/60...........AVC-Ultra:
The Panasonic AVC-Ultra family defines an additional three new encoding parameters within the MPEG-4 Part 10 standard, utilizing up to the 4:4:4 Intra Predictive Profile, as well as an additional low bitrate proxy recording mode.
The most efficient new parameter within AVC-Ultra is by Panasonic called, AVC-LongG. AVC-LongG enables compression of video resolutions up to 1920 × 1080 @ 23.97, 25 and 29.97p, with 10 bits of pixel depth at 4:2:2 color sampling, at data rates as low as 25 Mbit / sec.
More over, the AVC-Intra Class 50/100 is now extended to Class 200 and Class 4:4:4. The Class 200 mode extends the bitrate to 226 Mbit / sec for 1080/23,97p, while the Class 4:4:4 extends the possible resolution from 720p to 4K with pixel depths at 10 and 12 bits.
The bitrate settings for Class 4:4:4 varies between 200 and 440 Mbit / sec depending on the resolution, frame rate and bit depth. Both the Class 200 and the Class 4:4:4 are Intra-only coding modes.
The AVC-Proxy mode enables extremely fast ENG content delivery and offline edits of 720p and 1080p video at bitrates varying between 800 Kbit to 3,5 Mbit / sec at 8 bits of pixel depth.
It is. Now. Thanks to your last post, but no thanks to information being given out by Panasonic. Maybe there's a language and translation problem, but they seriously need to get a technical writer to clarify their published documentation. As it stands, it's a mess.With the upgrade to AVC-Ultra, the HPX600 becomes a beyond-HD camcorder. Just like the PMW300, with its upgrade to XAVC, will become a beyond-HD camcorder.
Hopefully that's all clear.
Well, it seems that AVC-Intra class 100 is an Ultra codec when used for 1080p/60, but not when used for 1080p/30.......vanvideo said:For what I understand, AVC-Intra class 100 (an Ultra codec) is a virtually lossless codec, almost uncompressed. Or that's what I got out of it.
