Will somebody post full-resolution grabs from their HPX?
Hunter Hampton
Carbonite Member
Or send me a link to look at some? I might want to pick up one of these and it would help me out!
Im just looking for uncompressed grabs, I dont care what glass is used!
Muchos Gracias,
Hunter
How did you export those stills? Whenever I export I end up with jagged edged photos like this:
I'm exporting from Final Cut Pro, (it looks fine in both FCP and if opened in Quicktime) at 1280x720. Plus the file I'm exporting the still from has already been exported as a completed video (so it's not a 960X720 file).
compression artifacts
are the grabs uncompressed out of your NLE? seems like they are somewhat noisy and with compression artifacts. otherwise excellent looking stuff.
Well, I tried a different file from raw footage and that was the issue. Apparently there's something weird about grabbing a still from an already exported quicktime movie. I took a screen grab of the file inside the Quicktime player so you can see the difference. I saved them via photoshop at "level 9" quality jpeg compression (the highest being 12 I believe).
Have you guys downloaded the new P2CMS? It works for mac. There's a frame grab function on the viewer. Double click on the file/shot you want to open/view. This brings up P2viewer. Then, on the bottom left of the screen there are some small icons. I don't know how to describe the icon, but just wait for a while and it should say "capture". It gives you jpeg, tiff and other format options for grabs, and they look fairly good.
This works with HVX footage, and should work with HPX...
