Colione
I have a Wiebetech Silver SATA-II, which is a 2 bay SATA enclosure that is confined to a RAID-1 (Mirror) or RAID-0 (One volume) configuration. For a while I only had one drive in Primary (top) slot of the enclosure. I recently got another drive. Weibetech touts that you can autobuild a drive by inserting a blank drive at any time, and the enclosure will rebuild your Primary drive. So I shut the machine off, inserted my new drive into the Secondary (Bottom) slot of the drive and turned the machine off.
What did the machine do?
It attempted to rebuild the SECONDARY (Bottom) drive to the PRIMARY (top) drive. I saw this on the LCD Display "REBUILDNG SEC->PRI"
So I freaked out and shut the machine off.
I called wiebetech and they said "well, we really shouldn't have labeled the drives PRIMARY and SECONDARY, they should really be labeled TOP and BOTTOM. If you turn the machine off you really have a 50-50 chance of rebuilding the drive you want, we apologize for that inconvience"
50-50 chance?!? Isn't that a little risky, especially for people trying to set up a RAID-1 to have ZERO chance of losing data?
Well, I lost 3 big FCP projects. I used Data Rescue II (which worked very well), but it brings me to the problem I need help with.
All of the Quicktime files recovered from the drive have now lost their file names. Is there ANY way of reconnecting the media based on length? or based on file size?
Does anyone have any fantastic ideas on how I could go about connecting my 300-400 media files that have no names?
Any thoughts would be great!
