TJIsACoolGuy
I am filming in Letterbox mode, and the stuff that isn't in filmed in letterbox I am just selecting 16:9 on the indivdual events. I am going to play this on a projector. I am wondering what settings I need to do to acheive this look when played on a projector. What I have been doing is using the standard 24p template (not widescreen) in vegas. And then on each clip I am selecting the event and making it 16:9. This seems to be what I want, because this makes a 4:3 image with 16:9 of actual usable footage in the center of the picture. This is what I would want when I play the video on a 4:3 screen. Correct? I am going to be playing probably off of a DVD or off a mini dv tape. What would everyone suggest? I know that I could choose the 16:9 widescreen template, but then I would be losing the 4:3 image and it wouldn't work with the screen I have, I need the black bars on the top and bottom. The other thing, is that when I save a picture from the preview window....(a still from a video clip), and I use it on my timeline, I can't select it like I can with video clips, and change the ratio to make it 16:9. So when I render out....unless I check the option to (not letterbox) than it looks funny when it switches to that picture, it jumps from being one depth, to another. For example, if you had video that you wanted to freeze on a certain frame for 5 seconds, and you save that still as a picture and put it in the timeline where you want it, it will jump from the video to the picture being zoomed out. Try it....So that's fine to fix it by checking that box, unless you are using the widescreen template, than you need to uncheck that box to have it be full widescreen and nothing else in the file. And when you uncheck the box, it messes it up. I wish there was a way to just click on the box on the picture event like you can do with any video clip and make it 16:9.
I don't know if this made any sense, but a simple explanation about how I should render out and project settings for use with a projector would be good. And an explanation as to all the different settings and when you render what that check box is for.
Thanks, I'm sure other people have wanted to know this too- because with all my past experiences with other NLE's, I've never seen anything this confusing for a render out.
