Widescreen Compression Resolution
maXspeed
Ok, I am either drawing a blank, or just not enough sleep, but i need help on this one lol
I only shoot in widescreen, and compress for web in 640X360 ( a bit smaller than the original)
This is gonna sound like a stupid question to someone with skills, but what is the true resolution settings (actual size of widescreen) if you wanna compress?
Thanks a bunch!
maXspeed
There isn't really a set size, all that matters is the ratio of width to hight.
But if you are talking about DV widescreen (which I think you are) then it would be 854x480.
I thought the max width in DV was 720? Where is 854 coming from?
854*480 will give you a 16:9 SD frame size. It's not an "offical" size, but it's better than kicking out an anamorphic or "squeezed" 720*480 file and hoping that the playback software will know to un-squeeze the image.
-A
the pixel aspect ratio changes from .91 to 1.2121 for anamorphic footage so a square pixel display system (computer monitor) needs the 854x480 dimensions for playback that is consistent, as adkimery said.
