Ok, but it seems bullshit. If VLC, and all other video players can smoothly playback DSLR H264 footage on a low end machine, why is Premiere (who is a much more powerful and expensive piece od software) not capable of doing the same?Different programs. You can't necessarilly use one as reference for how the other should work.
If its h.264 in a mov wrapper upgrading HW is pointless with CS4.
It's best to stay away from QuickTime if you can avoid it.
I have a powerful enough editing machine
Oh, I have a powerful enough editing machine and I know about offline editing...
Thank you for your answers, but I was just talking about bad programming...
I've edited a video an spent a lot of time color correcting, then exported it in HD H264. I Also calibrated my monitor with Spyder4ELITE befeore starting editing.
If i watch the final export in windows media player it is ok, and as crushed as it is in the Premiere Timeline, but if I watch it in VLC or Quicktime, it appears wither, with less deep blacks, and with some extra green where the blue should be.
What is this all about?
......VLC uses a method of playback called video hardware overlay (or just hardware overlay), which allows your graphics card to render the video directly without any input from the CPU or OS. Since you're bypassing the OS, the OS isn't applying any of it's color settings to the video (like setting the gamma or color corrections that are stored in the color profile for your monitor that was created when you calibrated).
If there is one update that was the most vital in the history of Premiere, it was going from CS4 to CS5.Oh, I have a powerful enough editing machine and I know about offline editing...
