Why DVD loops after exporting from PP CS6
novoluc
OK, this is driving me mad (and I really don't need that...)
Everything I export from Premiere ends up looping when I make a DVD. And I can't find why.
I export a sequence through Export->Media
I burn a DVD (VIDEO_TS & AUDIO_TS)
DVD plays just fine but!... at the ends it loops and restart.
And I don't want that. I want it to stop at the after the end, like it should.
It's not a problem coming from the soft to write the DVD, because I used several, checking all the parameters, and still the same looping.
So, what am I doing wrong with PP?
L.
What are you using to author and burn the DVD? That's where this will happen, not in Premiere.
What you're looking for is an end action -- the command for what happens at the end of the program.
Thank you for the prompt answer.
i did use Toast Titanium (OS X)
In Toast, I made sure the settings were correct (unchecked "auto-play disc on insert" and unchecked "play items continuously"
Should I try to erase all preferences for Toast, or re-install?
L.
L.
"Play all items continuously" is probably what's causing it to loop.
Will uninstall and re-install Toast, as to restart from scratch, and burn another DVD and check.
Thanks for your help.
L.
Try it in another player. A lot of DVD players will repeat the program if there is no end command or no menu to jump to at the end of the video. Otherwise, without an end command and menu, the player would just crash with a NOP error or go to the DVD player's splash screen.
What you should really do if you want control over how your video plays back is to author it properly (in Encore since you probably already have that). If you want to have a blank screen at the end of the video, make a black menu page with a hidden button to play the movie. The viewer can then press Enter and play it again if they want.
