MattinSTL
Sound Modulator
On most of the professional shoots I've been on I see the same little Sony 9" color monitor that I'm sure many of you have seen. It's a BIG BRICK for the little 9" screen... but the obvious reasons to use a professional monitor include precise color matching, over-scan, etc.
The reasons to use ANY kind of monitor expand to framing and composition, extremely precise focus, and to monitor the production so that you're instantly aware of everything that's going right or wrong. Once you use SOME kind of monitor you'll see how luxurious it is and you'll always want a larger referrence then the DVX lcd.
Many of the shoots I've been involved in have sudden schedule changes or location changes which often results in the need for a super-fast setup... and a good percentage of the time the subject arrives and we have to go with whatever we have... even if we'd like more tweaking. The gist is that on several occasions we don't get EXACT color matching on the monitor as what I have in the DVX. Since we're white balancing every shot change and I make sure everybody okays what they see in cam it's no big deal. What ends up happening is we just use the monitor to make sure the talent looks good and the shot looks good.
Even on the little 9" Sony you see SO much more then you'd ever notice on the DVX.
So my question is... How many of you pros are able to set up exact color matching every time? I guess if you have the monitor and the cam you should be able to do it very quickly... but still I wonder. Often times I see a warmer image in the DVX then I see on these little Sonys, but it's never been a problem (yet).
When I shoot by myself I use a Sharp Aquos for a monitor. I shopped around for a month or two before getting this lcd tv. Normally I detest the Sharp brand... but this particular monitor has really good color matching to the DVX straight out of the box... and you can tweak all parameters of the picture... plus flip the picture just like on the DVX lcd... so you can use it as a prompter or you can monitor a shot from the mirror perspective (like you might do to monitor yourself on cam).
I don't know if this is really amature to show up with an lcd tv and call it a monitor or not... but so far everybody that sees this setup is really impressed... without a closer look they think I spent a lot of money on this approach and yet it was DIRT CHEAP compared to a real monitor.
Any of you professional guys care to comment? I'm sure you'd say that you always get precise color matching with the DVX and monitor... but maybe some of you don't... and maybe you end up using your monitor like I always see them used... mainly as a tool for the director and producers... while the DP/cinematographer is primarily focused on the cam anyway?
My digi-cam couldn't perfectly sync with the lcd tv... so you see some odd bands between the individual color bars, but you don't see them in person... and I wanted to illustrate how good the color match is right out of the box.
