Who here uses a lightmeter while shooting DV?
MattC
If you DO use a lightmeter, please tell me what kind and how you use it. If you believe it is a tool of Satan, please tell me what you use to ward it off or kill it.
Matt
Re: Who here uses a lightmeter while shooting DV?
It's a tool of Satan and I've never used one. To ward it off, I use the normal method by which I ward things off... lighting a match and breathing on it.
I have a Sekonic DigiPro F from my 16mm lighting cameraman days.  Also used this a great deal when doing multicamera television and later in live-event and legitimate theatre.
Now, I use it primarily as a tool to get better stop to stop control between key and fill fixtures and the set itself. If you're lighting for an f4.0 or 5.6, zebra won't do a thing for you. I don't carry a meter around when shooting run-and-gun documentary, but it is indispensable for documentary interviews with three or more point lighting!
With this older digital meter, I have to actually assign an ASA to the DVX because it works on stops not footcandles or lux.  This is a PIA, but I am used to the conversion in my head.  I usually rate the DVX at 100 ASA and go from there.
e
Classic Norwood Director "Color meter". Just learning how to use it. I also use the zebras on the DVX. When I get enough cash I will purchase or bid on one of the digital ones on Ebay.
I heard from somewhere that using a light meter for DV isn't as important as using it for film. In fact, most peopel don't use it, do they? I'm curious if Walter Graff actually uses a light meter...
I use the Spectra Pro IV A, the same one Satan uses to measure footcandles in the flaming depths of HELL!
Good incident meter, it calculates key/fill ratios!
most videographers ( don't you hate that name?) do not use meters because the video camera actually is a meter all by itself. The zebras do the important work. On the other hand meters are good for getting consistent tone,shot to shot. This comes in real handy in post when cutting, otherwise one shots too dark, one too light ,etc... a constant fc will make for a smooth flow. Of course in reality most sets have hot and dark areas...so this gets messy fast. For film , a meter is a must until you can guess em.
