So just to clarify (i'm still learning all this):
so im assuming from what ive learned here, depending on your white balance, if you're balancing for either daylight or interiors, the apparent color of 5600k or tungsten fixtures will also change?
So that's why you should stick with only one lighting temperature for each situation? (within reason)
and also, in a bedroom scene for example, you set up your tungsten key/fill lights ect, then white balance, is the camera going to shift the color spectrum to make the tungsten scene more blue?
Because in that situation maybe the light is shining on white surfaces and making them look a little bit more amber colored, in which case you might not WANT to make white look "white"
I guess my BASIC question is, does White Balance maintain the integrity of your lights temperatures? Or does it try to tweak them to be something theyre not
