Which ones positive? (pics inside)
ryan brown
lOwEr CaSe Member
What'd ya think? which one's positive, and which is negative?
One is wrapped in white, and the other isn't wrapped in anything...
The foil outer wrapper (shield) will go to the outer ring of the rca jack, the center conductor will go to the center pin. If you're using for power, check for a graphic on the device - there's usually one showing the pin polarity near the socket. Although there is no standard, center pin is positive most of the time.
I would open the case and follow it and make sure Or go back to what ever it was connected to and use a multimeter to test for + and - at the power source.
Thanks... it is the one wrapped in white.
Starting a new thread about the functionality of the LCD itself...
