Which looses more light: Dichroic or equivalent gel?
Drcoffee
If I wanted to convert a blonde (2kw tungsten) to daylight, which would loses more light? a daylight dichroic filter or a full CTB?
Cheers
Jon
Full CTB = 36% transmission of light, in other words, you're loosing 44% of fixture's light. So a 1k will kick out around what a 350 gives you but with 5600k color temp. The other filter, ...? find the MFG. and look for spec. Gels are relatively inexpensive when compared to good glass filters.
I think dichorics will let more light pass thru than full blue gells. Dichorics are expensive and of course can break.
I thought the only difference between gels and dichroics are that the dichroic's don't fade over time. They're just meant to be used on lights where you constantly use them in daylight situations.
I am not sure but it seems to me that the same amount of light should pass through with either filter. There is only so much blue light from a lamp, the filters do not affect that amount, they only filter out the other colors.
