Thanks! Those sescom's are both a little more and a little less than I need... nothing seems to attenuate more than 14dB (and less than 40db), and I don't reall need a transformer (proicey!). The beachtek is not what I'm looking for in terms of elegance... but I have an old SignVideo beacktek knockoff that you just inspired me to try as a temp solution (set the unit for line-level, and use a 1/8 stereo to 2 TRS adapter to feed the MT...)
There are plenty of XLR barrel attenuators ot there, but I'd like to avoid 1) using an extra cable or 2) having long rigid adapters sticking directly into the XLR ports of the MixPre (since with their leverage they could potentially do some damage)...
Yeah, I guess that looks like the best solution until I find a chance to build an attenuator cable myself... I didn't think of the right-angle adapters, that might just do the trick...
Are you indeed using a similar setup with the MicroTrack? How's the noise level on the line-ins with this setup?
Thanks,
Barry
