where is file
yia
hi, guys
where did the file go or where is it save to after you fishing compressing in compressor?
Can I set where I want my to save to?... I been having problem finding my file after compressing..
thanks
The default in compressor is source.
When you drag up the settings for your output you will see the next section across is location - click on this and the window you took your settings from will change to locations - where you can add a custom location.
