Somewhereinthewoods
I'm about to do a short about solar energy. I will be using by HVX200 and a Canon 60D with a Tokina 11-16mm. I would like to make time-lapses but am afraid of hurting the cameras by aiming at the sun. Please advise.
I would just advise against using the HVX since it uses CCD's, which are prone to vertical smearing. You can reduce it by lowering the shutter speed, but I would just use the 60D if that's possible.
I've heard you shouldn't shoot the sun with a DSLR as it might damage the sensor. I'm not sure if it's true or not. Perhaps you can use a polarizer.
