When I render in Vegas I only use 60% of my CPU
I have an Intel 3.2 and the CPU usage meter never gets over 60% even when I am rendering a long video. You guys get similar results?
Is there a way to get Vegas to use the full power of my CPU so my renders are faster?
Re: When I render in Vegas I only use 60% of my CP
It probably only uses what it needs...
....but if you wanmt to experiment, you can go to the Task Manager | Processes, find Vegas and right-click on it...then set the Set Priority to something higher. Above Normal, High, or Realtime.
You'll get a warning, but go ahead anyway.
It may make no real difference in render times, though. I don't know...never tried it...
Dan
To maximize your CPU usage you could render two parts of your project simulltaneoulsy using top instances of Vegas, or you can set up a network render using two render nodes on the same computer (a bit complicated, but explained in detail on my Vegas 5 Companion video).
Gary
