What's the difference between DVCPro 50 and DVCPro HD?
billiamfilms said:
not to mention DVCPRO50 records at 50 MBPS (megabites per second) and DVCPROHD records at 100mbps.
Yeah... somebody needs to tell that to Zacuto cause they have some stuff on their website that says "DVCPro 50 HD".
DVCPRO 50 is 30fps interlaced 8 bit 4:2:2 color sampled standard definition at 50 megabits / sec. It can be used for progressive scan images using a 3:2 pulldown technique for recording to tape, which can be reversed in an NLE to deliver 24fps progressive 4:2:2 video. Solid state P2 media is capable of supporting standard definition 24fps progressive scan recording, with no need for 3:2 pulldown (camera model feature set permitting)
DVCPRO HD is 60fps progressive 8 bit 3:1.5:1.5 color sampled high definition at 100 megabits / sec. It can be used for variable frame rate recording (including 24fps using a 3:2 pulldown technique) from 4fps to 60fps to tape, that can be reversed in an NLE to deliver film camera style slow motion effects. Solid state P2 media is capable of supporting high definition variable frame rate progressive scan recording, with no need for 3:2 or other pulldown pattern techniques. (camera model feature set permitting)
HD recorded on tape
HD recorded on tape
To clarify - why is DVCPRO HD quoted as 3:1.5:1.5 and not 4:2:2?
There is no clear definition of how to describe the prefiltering that DVCPRO HD and HDCAM perform to their respective video signals prior to recording, so 3:1.5:1.5 is sometimes be used in conjunction with DVCPRO HD 720p, and 3:1:1 is sometimes used in conjunction with HDCAM 1080i / 1080p.
The math behind this is as follows. Full spatial resolution recording systems such as D5 record 720p with 1280 H x 720 V pixels for luminance and 640 H x 720 V pixels for the color difference signals. If that is the familiar ratio of 4:2:2, then 3:1.5:1.5 describes what a DVCPRO HD VTR records to tape - 960 H x 720 V samples for luminance and 480 H x 720 V samples for each of the color difference signals.
In a similar manner for HDCAM. Full spatial resolution recording systems such as D5 record 1080p with 1920 H x 1080 V pixels for luminance and 960 H x 1080 V pixels for the color difference signals. If those units are quoted in the familiar ratio of 4:2:2, then 3:1:1 describes what a HDCAM VTR records to tape - 1440 H x 1080 V samples for luminance and 480 H x 1080 V samples for each of the color difference signals.
In future, portable HD recording systems should be able to eliminate this form of image quality reduction, using more efficient compression algorithms and higher bandwidth recording media to deliver full spatial resolution 4:2:2 sampled images in both 720p and 1080i / 1080p.
What the hell? someones a little confused. Lol. I guess panasonic came out with a new intermediate media :-p.
