Ebrahim Saadawi
Carbonite Member
Removed for copyright matters.
Bokeh: it's the quality of the blurry out-of-focus areas of the image, a good lens will have round/circle blur with a creamy smooth look while a bad lens will have a harsh non-creamy look. This is best demonestrated here:
The right image the bokeh isn't circular, it's more distracting, while left one looks dreamy, smooth.
Perfect creamy/circular bokeh
You might wonder why a lens produces non-circular bokeh and some produce circular bokeh, it's determined by the shape of the lens "opnening", which is controlled by the number of iris blades. To demonstrate here: a lens with a low number of blades makes non-circular bokeh while a lens with a high number of blades makes circular more pleasing bokeh
In any lens specifications the number of iris blades will be mentioned, so now you understand why a higher number is better to have in a lens.
-An ideal lens would not have any of those defects, and the higher the quality the lenses are, the less defects they show, and the more expensive they get! So in low-budget photography/videography you'll have to make a few sacrifices and live with a few lens defects, so it's better to know what they are and try to hide/avoid them.
all you need to know is: larger sensor = better lowlight performance = easier ability to blur background = general better image quality simply as it can collect more light
Good write up though Ebrahim. That should help a lot of newbies and more experienced people alike.
The P number refers to the number of pixels that exist in the image in every row vertically, a 1080p image is one that's made of 1080 pixels vertically, and 1920 pixels horizontally.
