oleg said:depends - how much you can afford
everything better then the mike which come 3 with the tx
for low budget , the lectrosonics 152 can work as outside mike for interviews when the mike could be seen , don't live well under cloths.
the emw from countryman is very dissent mike , you need the picked version
the b-6 is very good option , the smallest mike with water resistance characteristics , working grate as hidden mike or over the cloths , the bad thing is the most sensitive to wind , so outside work is quiet hard
the sanken coss 11 is my favor for all around work , the best for ties and one of the best for cloths rustling
the dpa is excellent as well,good for loud voices , very natural sounding ,very low noise
the mke 2 is also very good sounding mike , but hard to work under cloths
so its about 100-400 $ to spend , if you buy lavalier ,buy it include power supply and just add brake connectors in the middle , that way you will be able to use it in hard wire situations when your receiver will have bad days , of course it would sounds better since wasn't chop inside the sennheiser
oleg said:I hope you will finish with good film ,its more important then what mike you use , eventually they will dub the audio track anyway if it going to be international wide![]()
