What is the workflow for editing 4k footage?
FilmBoy77
When using the latest version of premiere what is the workflow for editing 4k footage? I was reading somewhere where you ave to downrez it first in order to edit it so that your CPU doesn't get bogged down, etc. Is this true? If not, what is the workflow?
It really depends on the gear you have. If you a fast enough computer connected to fast enough, big enough storage to hold everything you can edit in 4K. I've only messed around with 4K and 5K footage but if I just drop my playback res to 1/2 it all plays fine and if I drop it to 1/4 I can then even do things like green screen comps with some color correction in real time. I've got a 2009 MacPro with an Nvidia GTX 660 Ti GPU so it's not like I'm working with bleeding edge tech.
-Andrew
-Andrew
Ah ok nice maybe I should be okay then. How much RAM and processor speed do you have?
It also depends on the codec you choose for your footage. Some require more horsepower than others for smooth playback. So you might need to transcode your footage to a different codec that it was acquired on.
I haven't had any issues playing the footage back and previewing it so far.
Is there anything I can do once I finish to get the anamorphic 16:9 look without any of my image being cropped out? This footage was filmed at 4096x2160.
