From my understanding, if you do not use the 180 degree rule and use a faster shutter speed, your footage would produce a sort of crispier look in regards to the motion. As though you are seeing the motion clearly, like fast robotic movements. If you were to slow down your shutter speed based on the 180 degree rule, the motion would start to look mushy.
If you were to follow the 180 degree rule on a 50 fps footage and use it on a 30 or 24 fps timeline, what effect does this do? Does it produce the same quality footage as if it were on a 50 fps timeline or does it change it somehow and if so, what sort of changes?
What sort of effects happens when you exceed the 180 degree rule and use a different fps to what it was originally recorded.
What happens to the image - quality, motion, etc. Does it create noise, how does it affect the blur or crispiness of movement, color, etc.
What sort of affects happen when you use the 4K footage on a 1080 timeline with the above situations?
Is there a guideline as to how these sorts of situations work?
Thanks.
Thanks.
