What codec is best to convert to in Media Encoder
Adam Gonzalez
Shooting with the 7D. Looking to convert footage so PPRO can handle the footage better for editing. What would be the best codec to convert the files into? Thanks!
I don't see the point either converting mpeg4 to mpeg4; both highly compressed.
Ppro can handle dslr footage natively but if your machine can't, get a powerfull editing rig or use Cineform for easy editing.
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC
As you see her you know nothing of what you speak.
H.264/MPEG-4 AVC is merely a group name of a thousand ways to compress, each gives the computer something else to think about.
For example h.264 in level 5.2 can be encoded at 720mbit/s
Or, just use ProRes. Perhaps you could consider doing an offline edit using proxy files (you could even use an SD format) and then linking them back to your original files during colour correction?
Whats the easiest way of doing offline edit using proxy with premiere?
Well if you really want to know there are different kinds of mp4, mov and stuff that should be h.264 but if the camera is doing a bad or overly complicate encode, a reencode to h.264 HDTV give you a stable and reliably file.
What you are doing would be like taking a 192kps MP3 file and saving it as a 320kps MP3 file. It makes no sense to do it that way, especially given that Premiere will work with the native files coming off your camera. Convert it to DNxHD, ProRes, or, hell, even DVCPRO-HD instead. Don't convert one H.264 format to another unless you are doing the final render out.
Especially not for editing.
There's also Cineform. It costs a bit of money but it's cross platform. It has a free trial if you want to give it a go...
