Just bought a M2 from someone and can't get the dvx100b to connect directly to M2?
Also, it came with HD 72mm lens but shouldn't I use SD 55mm lens for dvx100b? I'm sorry if this is stupid question!!
I know this sounds crazy but what do you mean when you say threading? and do you think I need a step up ring bc on the M2 it has the 55mm lens with the soft hood?
Threading is the diameter of the filter threads on your camera. And did the M2 come with a step down ring from 72mm to 55mm? Or is it just 55mm. With the latter, yes, you'll need a step up ring.
