What Am I Doing Wrong??
aalleexx
First Day Of Shooting And Everything Goes Bad, Damn I Thought I Knew My Camera Here Is The Problem Guys
I Have A Dvx 100b And I Was Shooting Fine The Problem Is That I Want Two Levels Of Audio In My Vegas And When I Transport The Clips To Vegas It Only Shows One Channel Of Audio, Why? I Want To Use The Internal Mic As One Channel And An External Mic As Another
I Have Channel 1 Set To Imput 2 And Channel 2 Set To Internal
And Mic Power Is Turned On, On Imput One, Is The Problem In Vegas Or On Camera? Thanks
Try this
Try this
Try this:
Select Channel 1: Input 1
Select Channel 2: Int (R)
Input 1: On
Input 2: Off
This is usually my setup when using one shotgun and the internal as backup. I also would double-check capture settings in Vegas and make sure you audio track settings indicate both, not left or right only.
Vegas will digitize the clip as one stereo track. Copy the track so there are two of them, and select right only on one, and left only on the other.
