Run&Gun
Plural (more than one camera) vs. blanket (all cameras). For example, the Alexa Studio does not have a full spectrum ND and is stated as having color shifts: http://cinematography.net/ir-grabs/ir-grabs.html (F55 and 65 stated as full spectrum; note color shifts on these NDs). Quick search didn't find F55 internal ND examples- have you specifically tested yours (might not be noticeable for everyday shooting)?
I only found this out by doing a deep dive color analysis for skin tones (google: Filmic Skin C300 II, for more info). It's not an issue, just something I observed from real-world testing; perhaps a few hundred Kelvin- easily fixed with WB or in post. It appears lower cost NDs shift light at different frequencies (colors) non-linearly, so it's not possible to fully correct with a simple WB adjustment. Apparently it's a complex problem, otherwise Canon could build in auto-compensation when the internal NDs are engaged (or perhaps Sony did a better job with software correction). Colors are jumping all over the place with these NDs as well: https://nofilmschool.com/2013/08/true-nd-filter-color-shift-test
Given the lack of true color calibration for current cameras systems (all the way to the top), everything is ultimately adjusted in post (getting computer and monitor systems accurately calibrated is another issue).
I'm sorry, but that still reads like a generalized statement. Had you said "some cameras", that would have been more clear. Not being argumentative, just saying'...
ALEXA's don't have built-in ND(AMIRA's do) and ND, especially inexpensive filters, but also expensive well-known brands, can be all over the map with color shift and IR. I don't have the "it's good enough" philosophy, but when I said I have no issues, I meant that I have not seen anything visually objectionable(like noticeable IR pollution or color shifting) on my calibrated monitors, not on scopes. That's arguably all subjective, but so much of what we do it is.
