Same project again, different problems, thought it was better to make new threads...hope you agree mods.
Footage = 24AP DV NTSC 16:9 squeeze / 24AP 4:3 DV NTSC / 24p (some lurking)
this seems to be a problem across the board on the different clips
SOME of the footage has this weird look where you can see vertical lines...or even large cubes (pixels?). It seems to happen a lot with things that are over exposed. I will try to post an example. I've noticed it both on the squeeze and 4:3, and tried pulling the footage into different editing timebase to rule out the possibility of compression. My gut feeling is its just something that happens with the DVX100 when its overexposed? I don't know if there are other over exposed clips that have this problem. It does appear in some clips that aren't particularly over exposed as well.
What can we do?
What can we do?
