Jim Brennan
VHS Member Old Skool
I used the exact same graphic in two separate video files from FCP. I imported them both as assets into SP4. One I used as the background for some text in a transition video, one as the menu background. There is a marked difference in image quality between the two. When you you hit play, the menu goes directly to the video (it's continuous), so you can see the difference plainly. In the menu it's fuzzy, then it's clear as the video starts.
Anybody else have this problem, and is there a way to fix it?
