M. Gilden
Canon DSLR Moderator
This problem has been driving me crazy on my main Win 7 workstation for a while now, and I can't figure it out.
After Effects seems to render out corrupted frames randomly whenever I use any AVI or MOV formats (I used to blame it on VFW issues, but it seems to happen with QT as well now!).
I noticed it first when using DNxHD, so I switched to Cineform- but no luck. Generally, the problem seems to be frames that just come out blank when loaded into an NLE like Sony Vegas. Always in the same location. When I try to play it back in WMP, it freezes up at the point the blank frame appears, while the audio continues.
I tried just using a standard Quicktime codec, like Animation or YUV 4:2:2, and while the frames aren't blank, they are still corrupted as you can see in the attached image:
Notice the scrambled static looking pattern on the top of the frame? That randomly appears throughout the footage, sometimes smack in the middle of the frame. Just about any AVI or MOV codec and combination of options I've tried does this.
This is ever so frustrating, the only way around it seems to be choosing a lossy format such as H.264. Which is obviously less than ideal.
Has anyone ever encountered anything like this before?
