Warp Stabilizer help!
RyanHoj
Okay so here is my process: import my clip to after effects, user warp stabilizer and it does both of its steps so stabilize it, save it, export as a premiere pro project, but when i open it in premiere i get this error
When i use the warp stabilizer tool with after effects and i go to import it to premiere i get this message:
C:\Users\Ryan\Desktop\warp test 4.prproj
Video Filter missing: AE.ADBE SubspaceStabilizer
anyone know why?
nevermind found my answer! If anyone needs help and sees this, just render the clip after the warp stabilizer and you will be good.
Do you have standalone versions of these products? You may running into a dynamic link issue. Dynamic link is only available in Production Premium and Master Collection suites.
Typically the workflow is to work from Premiere Pro, select the clip, choose File>Dynamic Link>Replace with After Effects Composition. Your clip then opens in After Effects where you do your stabilization. After the analysis is complete, the effect will update in Premiere Pro.
For what its worth, I'm getting better results at the default settings using WS than in other 3rd party products, especially with tricky shots. And don't use 'subspace warp' unless you have lots of parallax movement, or are a star trek fan:)
