Noah
I know that with a wall spreader you need 2x4's cut to size for the room (or speed rail, depending on the spreader you buy) while an autopole just telescopes. I really want to know the weight capacity difference. I haven't used either of them and am going to be shooting some scenes in small nyc apartments, so having one or two of these in my arsenal would be a great asset. From my understanding, with a wall spreader, you cut one side of the wood at an angle so that the more weight is put on the spreader, the more pressure it applies to the walls. Is this correct? How much weight can this hold versus an autopole? If anyone can tell me how much stuff they've hung on one in the past, as an example, that would be helpful as well. Clearly, the greater the distance of the spreader, the less weight it can hold as it can sag in the middle, but I'm looking for a ruff estimate. I want to know, for instance, if I'm going to be able to throw a few 1k's and tweenies up there with some arms holding flags and nets and not have it come crashing down on my crew and actors' heads. THanks
