Vimeo embedding enabled on DVXuser!
Ok... you can embed vimeo videos now. I'll get a button in the wysiwyg editor soon, but for now you can do it manually.
Just use:
vimeo
as the tag.... you would enclose that work in [] tags at the front.
then enter the series of numbers for the video (not the whole url, just the id) and then close the tag with [/vimeo]
For example
I will replace the brackets "[]" with BR for illustration purposes:
BRvimeoBR2111305BR/vimeoBR
Make sense?
later,
Jason
I would suggest to all that you not copy and paste from word or edit an exsisting link etc....type in your vimeo video id # and put the tags in manually....
daniel... you can also use the vimeo button (a blue v) and it will generate the tags for you if you aren't used to typing it on your own... then just drop the clip id (the series of numbers) inbetween the tags.
button shows when creating a new thread, and if you use the advanced editor as opposed to the quick reply when posting in an existing thread and/or modifying an existing post.
