Story1kanobw
Why is video played in Adobe Speedgrade uneven and slow?? The sound is also choppy. I exported 2different sequences into speedgrade and got the same result. I imported acineform hd file into premiere (14 gigs). There is no preset sequence that exactlymatches that cineform file, but I imported that file then chose the"change the sequence setting to match clip" option. Or is that not ok?Should be ok because that file played great in Premiere 6. Then I exported that file to Speedgrade.Once in Speedgrade the video played a bit normal but mostly slow and sound was choppy. Why??The same happened with .mov video from my Canon 5D mark 2. My hardware ; AMD Phenom II X 4 Processor 3.2 GHz, 8 Gigs RAM, 64 bit Microsoft Home Premium. Is it a hardware issue? Are there adjustments I need to make on the Speedgrade options?
