Video causing software to crash at certain point with P2 data, however audio will not
rzr219
Ok, so this is the 2nd time my software has done this. First time I thought it was plural eyes messing with the audio files.
This time I have only the P2 files off the cards that I shot. I can preview it in P2 viewer and no issues at the point where it causing premier to crash. At first I thought it was the spanning feature of the camera HPX250, however its approx. 2 minutes past that point, it started on a 16GB card, then switched to a 64GB card like normal.
I tried it on another system I have and it plays fine and doest not crash, however that system is not really meant to edit video, just photos. So in the short term I will export the video then reimport it and overlay the audio. However this really sucks, so I was hoping to see if someone might have a answer to why my system started doing this. I have dumped the chase files and rebooted and tried importing just the 64GB file, then the 16GB file no difference. So any ideas?
I can't attach my entire crash report too long it says.
Process: Adobe Premiere Pro CS6 [356]
Path: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
Identifier: com.adobe.AdobePremierePro
Version: 6.0.5 (6.0.5)
Code Type: X86-64 (Native)
Parent Process: launchd [154]
User ID: 501
Date/Time: 2016-04-15 15:36:13.034 -0500
OS Version: Mac OS X 10.8.5 (12F2560)
Report Version: 10
Interval Since Last Report: 709178 sec
Crashes Since Last Report: 24
Per-App Interval Since Last Report: 154103 sec
Per-App Crashes Since Last Report: 17
Anonymous UUID: B05F0855-181B-5937-4A04-0C49AA1E0FE5
ok, I just had it crash on the other system also. I ran a quick test and so far it seems to be working. I copied the files directly off the camera this time. Last 2 times I have used my AJ-PCD20, using copy and paste. So if this is my issue (fingers crossed) what is better Shotput or P2 viewer, cost is close to the same. I am not sure if I will be keeping my Mac as soon it needs to be replaced, so any thoughts?
So I just downloaded ShotPut and that seems to have taken care of the error in transfer ( I tested with the new check sum setting) I didn't even knew I had at times. Very frustrating and I have never before had issues, oh well this just goes to show that sometimes learning the hard way is the best way to learn from your mistakes.
